Source Code
The source code for the plugin can be found at: Gaea2Unreal Github Repo
The main branch contains the latest version. Any work-in-progress can be found in a dev branch while, past releases can be found in numbered version branches such as UE-5.3.
Issues should be opened only for the source code. For usage or other issues, you should contact QuadSpinner Tech Support.
