Build Reports
Post-Action Screen
Gaea shows a post-action screen when a build finishes. It saves a copy in the build folder as report.txt so you can refer to it later.
───────────────────────────────────────────────────────  GAEA BUILD SWARM  2.1.0.0 ──
          Filename:  │ C:/Users/Dax/Documents/Gaea/Projects/mesher2.terrain
    Build Location:  │ C:\Users\Dax\Documents\Gaea\Builds\mesher2\001
        Build Type:  │ Standard
  Build Resolution:  │ 2048 × 2048
     Build Profile:  │ None / Last Saved Settings
             Nodes:  │ 03 to build
                     │ 01 to export
───────────────────────────────────────────────────────────────────── Build Report ──
              Build Results                              Statistics
          Result: │ Success                  Sandstone │ 0:00:02.721
      Resolution: │ 2048                               │
      Node Count: │ 3                          Fastest │ Mesher @ 0:00:00.001
      Start Time: │ 02/05/2025 19:42:03        Slowest │ Sandstone @ 0:00:02.721
        End Time: │ 02/05/2025 19:42:26
        Duration: │ 00:00:23.3091200       * nodes that took <100ms are excluded.
  Non-Build Time: │ 00:00:20.5231200
Build Report
A structured data version of the report is also saved as report.json that is both human and machine readable.
  "$id": "1",
  "Resolution": 2048,
  "NodeCount": 3,
  "Result": "Success",
  "StartTime": "2025-02-05T19:42:03.2694437+05:30",
  "EndTime": "2025-02-05T19:42:26.5785637+05:30",
  "Duration": "00:00:23.3091200",
  "SecondsTaken": {
    "$id": "2",
    "$values": [
        "$id": "3",
        "Item1": "Perlin",
        "Item2": "00:00:00.0640000"
        "$id": "4",
        "Item1": "Mesher",
        "Item2": "00:00:00.0010000"
        "$id": "5",
        "Item1": "Sandstone",
        "Item2": "00:00:02.7210000"
  "FastestNode": {
    "$ref": "4"
  "SlowestNode": {
    "$ref": "5"
