Portable Installation
Please make sure you have read the Install Gaeapage.
Running the Setup
Our new installer makes it very easy to install Gaea, even when you may not have Administrator privileges.
Choosing the Installation Type
To begin the installation select Regular Installation or Portable Installation. If you don't have Administrator privileges, select Portable Installation.
Choosing the Path
Next, select where you would like to install Gaea.
By default, it will install to C:\Users\YOU\AppData\Local\Programs\Gaea 2.0
You can save to a more accessible or memorable path if you prefer. You can install it on a USB drive.
Gaea will now install. You will be given an option to launch Gaea once the installation is finished.
Welcome to Gaea
Once Gaea launches, you will be presented with this Welcome dialog.
You can set your Gaea Projects storage path here, and select the navigation style for the Viewport.
License Key
If you have a License Key, you can also enter it here to activate all the features of your Gaea Edition. You can find the License Key in the email you received after purchasing Gaea 2.
You can also enter your License Key from the Start Screen whenever you start Gaea, or from Help > About menu item. See Licensing for more details.
File Licenses
For users who have been issued a file-based key, just drag and drop the file (usually a XYZ123.lic file) on the license dialog. Gaea will automatically consume the file to authorize your copy.
Gaea is now installed and you are ready to create Terrain Basics!
Facing issues? See Troubleshooting
