Build Swarm
The Build Swarm, represented by Gaea.Swarm.exe is the heart of Gaea. It is the Build Engine that takes the terrain recipe created in the Gaea UI and builds it with high performance.
The Swarm is a separate command line executable so it runs faster without a UI burdening it. Gaea's UI uses it in the background when building high resolution terrains for maximum performance.
Options
All options for the Build Swarm for a specific file can be set in the Build Options.
Some additional options can be set via Command Line Automation.
Automation
See Command Line Automation and Variables for automation scenarios.
Post Action Report
Gaea will save a post-action report as both human readable and machine readable files. You can use them in your automation workflow or use them to gather vital intelligence about your builds.
