Paths and Storage
Data
Gaea stores all application data, excluding Projects, in a centralized directory known as the Data folder.
Install Type Flag Typical Path Data Folder Path
Non-Admin /CURRENTUSER C:\Users\<user>\AppData\Local\Programs\Gaea 2.0 C:\Users\<user>\AppData\Local\Programs\Gaea 2.0\Data
Admin /ALLUSERS C:\Program Files\QuadSpinner\Gaea 2.0 C:\Users\<user>\AppData\Roaming\QuadSpinner\Gaea\2.0\
Standard Installation
If Gaea is installed in the Program Files directory, the Data folder is located at:
<UserFolder>\AppData\Roaming\QuadSpinner\Gaea\2.0
Portable Installation
The default location for a Portable Installation is:
C:\Users\<username>\AppData\Local\Programs\Gaea 2.0
If Gaea is installed in a portable location, the Data folder is located adjacent to the Gaea.exe file.
For example, if your install location is: D:\Programs\CG\Gaea\ then the Data folder will be stored at D:\Programs\CG\Gaea\Data\
Whenever a new installation of Gaea is created, upon first run, Gaea will check if the install folder is writeable (ie, does it require Admin Privileges). If it is writeable it will create the Data folder there, otherwise it will create it in AppData.
Your Gaea Files
These paths can be changed in the Options > Paths.
Documents
This is where all Presets, Screenshots, and other Gaea documents are stored.
Default location: C:\Users\<you>\Documents\Gaea\
Projects
The is where all Gaea project files are stored by default.
Default location: C:\Users\<you>\Documents\Gaea\Projects\
Builds
This is where output files from builds are stored. It is denoted by the token <Builds> in Build Destination.
Default location: C:\Users\<you>\Documents\Gaea\Builds\
