Build Reports
Post-Action Screen
Gaea shows a post-action screen when a build finishes. It saves a copy in the build folder as report.txt so you can refer to it later.
─────────────────────────────────────────────────────── GAEA BUILD SWARM 2.1.0.0 ──
Filename: │ C:/Users/Dax/Documents/Gaea/Projects/mesher2.terrain
Build Location: │ C:\Users\Dax\Documents\Gaea\Builds\mesher2\001
Build Type: │ Standard
Build Resolution: │ 2048 × 2048
Build Profile: │ None / Last Saved Settings
Nodes: │ 03 to build
│ 01 to export
───────────────────────────────────────────────────────────────────── Build Report ──
Build Results Statistics
Result: │ Success Sandstone │ 0:00:02.721
Resolution: │ 2048 │
Node Count: │ 3 Fastest │ Mesher @ 0:00:00.001
Start Time: │ 02/05/2025 19:42:03 Slowest │ Sandstone @ 0:00:02.721
End Time: │ 02/05/2025 19:42:26
Duration: │ 00:00:23.3091200 * nodes that took <100ms are excluded.
Non-Build Time: │ 00:00:20.5231200
Build Report
A structured data version of the report is also saved as report.json that is both human and machine readable.
"$id": "1",
"Resolution": 2048,
"NodeCount": 3,
"Result": "Success",
"StartTime": "2025-02-05T19:42:03.2694437+05:30",
"EndTime": "2025-02-05T19:42:26.5785637+05:30",
"Duration": "00:00:23.3091200",
"SecondsTaken": {
"$id": "2",
"$values": [
"$id": "3",
"Item1": "Perlin",
"Item2": "00:00:00.0640000"
"$id": "4",
"Item1": "Mesher",
"Item2": "00:00:00.0010000"
"$id": "5",
"Item1": "Sandstone",
"Item2": "00:00:02.7210000"
"FastestNode": {
"$ref": "4"
"SlowestNode": {
"$ref": "5"
}Last updated
