Paths and Storage
Data
Gaea stores all application data, excluding Projects, in a centralized directory known as the Data folder.
Standard Installation
If Gaea is installed in the Program Files directory, the Data folder is located at:
<UserFolder>\AppData\Roaming\QuadSpinner\Gaea\2.0
Portable Installation
The default location for a Portable Installation is:
C:\Users\<username>\AppData\Local\Programs\Gaea 2.0
If Gaea is installed in a portable location, the Data folder is located adjacent to the Gaea.exe file.
For example, if your install location is: D:\Programs\CG\Gaea\ then the Data folder will be stored at D:\Programs\CG\Gaea\Data\
Your Gaea Files
These paths can be changed in the Options dialog.
Documents
This is where all Presets, Screenshots, and other Gaea documents are stored.
Default location: C:\Users\<you>\Documents\Gaea\
Projects
The is where all Gaea project files are stored by default.
Default location: C:\Users\<you>\Documents\Gaea\Projects\
Builds
This is where output files from builds are stored. It is denoted by the token <Builds> in Build Build Destination.
Default location: C:\Users\<you>\Documents\Gaea\Builds\
