File Formats
Gaea supports all modern (and some legacy) file formats for both flat files and meshes.
For Import
Bitmap Formats
OpenEXR
TIFF
PNG (64 / 16 / 8)
RAW (Float / Half / UShort)
JPG
Gaea RAW
3D Formats
Wavefront OBJ (.obj)
Autodesk Filmbox (.fbx)
Collada (.dae)
WebGL (.glTF/.glb)
Point Cloud (.xyz)
For Import
Gaea supports the following formats for importing data:
.exr
.tif/.tiff
.webp/.jpeg
.webp
.svg
.psd
.hdr
.pfm
.r32
.raw
.bmp
Gaea's Project Formats
Gaea saves files in the formats mentioned below.
.terrain
Gaea terrain projects are saved as a .terrain file. All Gaea editions can read this format.
See Command Line Automation for manipulating this file format.
Precision
Gaea stores and processes its heightfields in 32-bit floating points, which is compatible with all professional CGI applications.
32-bit
For practical purposes, exporting as either OpenEXR or TIFF will give you the best results and maximum compatibility with other applications. If you are using a custom pipeline, using R32 or PFM formats may be of more use. See the section below for those formats.
16-bit
While displacement/heightfield information requires 32-bit precision for accuracy; color maps, masks, and other secondary data which may have fewer levels of complexity can make use of 16-bit formats, such as PNG. This can help save on disk space as larger worlds will require a lot of storage space. Storing in 16-bit also helps performance.
In fact, if your terrain does not contain many smooth details, you can even export your main displacement as 16-bit.
Game engines, such as Unity, can only import RAW 16-bit (ushort) format terrains.
8-bit
In some cases, for example with black and white masks, you may not need a high level of precision at all. You can use 8-bit PNG or TIFF output which can increase performance and save disk space.
Custom Workflows Precision
If you are using Gaea in a custom workflow, such as automation, you may require the data to be as simple and efficiently readable as possible.
Technical Details
32-bit float (.r32) and 16-bit ushort (.raw) are the simplest formats you can use. It is a simple binary array of float (IEEE 754) or unsigned short. The file has no header and can be read directly as a binary stream. The files will use Little Endian.
The size of the heightfield should be square root of the byte length divided by the size of the type (4 bytes for float, 2 bytes for ushort).
The .r32 format will store values between 0.0f and 1.0f. While the .raw format will store values between 0 and 65535.
Both formats are recommended for heightfield (grayscale) data only.
