Graph Conveniences
Gaea supplies numerous quality-of-life features to help you create and navigate complex graphs with as little effort as possible. These conveniences can reduce your workload dramatically when adopted into your standard workflow.
Create Nodes
Shortcodes
Each node has a corresponding shortcode. For example, Perlin is p, Mountain is m, Erosion2 is e2, Cone is con, and so on.
You can enter the shortcode instead of the full name when searching for nodes.
Chained Creation
You can use shortcodes (or full names) to quickly create a linear sequence of nodes. As you press the , key, Gaea will expand the shortcode or the first matching node in the Search results.
Enter m,e2,e2,tb,sm to create Mountain > Erosion2 > Erosion2 > TextureBase > SatMap.
Out to Out
When you drag a connection from an Out port and connect it to another Out port, instead of denying the connection as a disallowed right-to-left direction flow, Gaea will create a Combine node and route both Out ports to the Combine node.
MultiMix
Combine: MultiMix can be called from the Graph toolbar or by simply pressing F8. It connects the primary Output of all selected nodes to one or more inputs in a Combine node.
Mixer: Alternatively, if you press Ctrl + F8 or select the To Mixer option in the Graph toolbar, the outputs will be connected as Layer inputs for a Mixer node. This is useful when you want to layer multiple color textures and mask them using the Mixer node.
Portals
For detailed information on Portals, see Portals and Chokepoints
Convert Connection to Portal
Right-click on a connection and select "Convert to Portal" (or press Ctrl + P to convert an existing connection to a Portal. This will also convert the Out port to a Portal.
Other connections associated with that Port will not be affected.
Insert Node
Right-click on a connection and choose "Insert node." This action opens a search menu.
Select the node you wish to insert from this menu, and it will be automatically placed between the existing connection.
Connect to Portals
When you press P to bring up the Portal Management menu and select an In port, you will be presented with a list of available Portals that can be consumed.
Navigation
Navigate Menu
Press the
,key while a node is selected to open the navigate menu. This menu displays all incoming and outgoing connections linked to the selected node.Click on a connection within the menu to select and automatically navigate to the corresponding node.
Node Bookmarks
Allows you to bookmark selected node. When a node is bookmarked, it is shown in the bookmark menu. Clicking on the node will select and navigate to that node.
Organization
Select Nodes
You can select all nodes upstream (ancestors) or downstream (descendants) of a specific node from the Node menu or the Menus and Toolbars.
Group/Ungroup nodes
To create a group, select multiple nodes and choose "Group/Ungroup" from the menu. This action groups the selected nodes together. Clicking "Group/Ungroup" again while a group is selected will ungroup the nodes, placing them individually back onto the graph.
Combine nodes
Select two or more nodes and click on the "Combine Nodes" menu option. This will connect the selected nodes using a combine node.
Convert port to portals
This feature displays a list of output ports. Click on a port to convert it into a portal.
Move to Tab
This option provides a list of graph tabs. Click on a tab to move the selected nodes to the selected tab.
Auto Layout
Pressing F4 when one or more nodes are selected will automatically layout the nodes.
Push Nodes
Dragging the cursor on the graph while holding Ctrl + Shift lets you push all nodes to the right of the cursor. It is a handy tool to quickly organize portions of a graph.
Ctrl + Shift + LMBLast updated
