QuadSpinner Gaea
Download GaeaTalk to Support
  • User Guide
  • Node Reference
  • Changelog
  • Home
  • Getting Started
    • Install Gaea
      • Regular Installation
      • Portable Installation
      • Mass Deployment
      • Troubleshooting
      • Version Numbers
      • Uninstall or Clean Install
    • License Management
      • Activation
      • Deactivation
      • Hardware Thumbprint
      • Floating License
    • User Interface
      • Graph
      • Viewport
        • Render Modes
        • 2D Viewport
        • Measurement Tools
      • Property Editor
        • Modifier Stack
        • Presets
        • Binding Variables
      • Data Editor
        • Terrain View
        • Export View
        • Automation View
      • Menus and Toolbars
        • Main Menu
        • Undo and Autosave
        • Graph Toolbar
        • Viewport Toolbar
        • Property Editor Toolbar
        • Data Editor Toolbar
      • Lazy Menu
      • Keyboard Shortcuts
    • The Graph
      • Procedural Workflow
      • Toolbox and Search
      • Lock Preview and Underlays
      • Suspending Engine
      • Graph Conveniences
      • Portals and Chokepoints
      • Organizing with Tabs
      • Annotations
      • Groups
    • Managing Gaea
      • Command-line Interface
      • Options
        • Compute
      • Autosave and Recovery
    • For Gaea 1 Users
      • Migration Guide
      • Node Changes
  • Using Gaea
    • Terrain Basics
      • Creating a Snow Mountain
      • Creating a Simple Landscape
      • Exporting Elements
      • Importing Meshes
      • Masks
      • Non-Determinism
      • Scale and Resolution
      • Memory Requirements
    • Crafting the Surface
      • Noises, Primitives, and Landscapes
      • Erosion
      • Surface Nodes
      • Transpose Shapes
    • Understanding Erosion
      • Erosion_2
      • Erosion_1
      • Thermal Erosion
      • Additional Erosion Nodes
      • Nuance
    • Simulations
      • Snowfall
      • Debris
      • Water
      • Vegetation
    • Colorizing and Textures
      • Crafting Masks
      • Working with SatMaps
      • Synthesizing Colors
      • Layering Textures
      • ColorErosion
    • Managing Graphs
      • Using Modifiers
      • Visualizing Scale
      • Accumulators
      • Navigating Complex Graphs
    • Baking Nodes
      • Linchpin Nodes
    • Build and Export
      • Exporting Nodes
      • Build Options
        • Managing Regions
      • Tiled Builds
      • Using Regions
      • Profiles and Batch Builds
      • Batch Builds
      • Mesh Exports
        • Tangent-Space Normals and Warped Maps
      • Application Specific Export Nodes
        • Unreal Node
        • Unity Node
    • Importing Terrains
      • Universal Instructions
      • Software-specific Instructions
        • Unreal
      • Common Issues
  • Advanced Topics
    • Build Swarm
      • Creating Mutations
      • Build Reports
    • Technical Information
      • File Formats
      • Learning and Predictive System
      • Paths and Storage
      • Dimensions and Scale
      • Calculating Memory Requirements
    • Automation
      • Command Line Automation
      • Managing Input and Output
      • Building a Bridge with the CLI
  • Plugins
    • Gaea2Houdini
      • Installing Gaea2Houdini
      • Using Gaea Nodes
    • Gaea2Unreal
      • Installing Gaea2Unreal
      • Importing Weight Maps
  • Developers
    • Scripting and Expressions
      • Variables
      • Expressions
      • Math Node
    • TOR Platform SDK
  • Troubleshooting
    • Terrains
      • Common Errors
      • Terrain Quality
    • Diagnostics (Watson)
      • Diagnostics Package
      • CPU Only Mode
      • Benchmark Devices
Powered by GitBook
LogoLogo
Copyright © 2020-2025 QuadSpinner. All rights reserved.
On this page
  • Key Export Elements
  • The Terrain
  • Color Map
  • Masks
  • Point Clouds
  • Normals and Splat
  • Ambient Occlusion and Rock Occlusion
  • Rendered / Baked Lighting
  1. Using Gaea
  2. Terrain Basics
Exporting Elements
PreviousCreating a Simple LandscapeNextImporting Meshes
Last updated 6 months ago
Gaea is primarily an asset generator designed for creating and exporting terrains to be used in other applications. It supports all major heightfield and mesh formats, ensuring compatibility with various platforms and rendering tools.
Key Export Elements
Below is a list of common elements you may wish to export, and the nodes you can use to get those elements.
The Terrain
This can either be a 32-bit displacement map or a high precision mesh. It is the most essential part of your project. Game engines would use 16-bit displacement maps.
Color Map
If you have constructed a color map that will be the Diffuse/Albedo map for your terrain, then this will be exported as either an 8-bit or 16-bit bitmap.
Masks
Various aspects of the terrains such as the slope (Slope Map) or flow of sediments (Flow Map) can be exported as bitmaps to control map blending, masking, and driving scatter instances. These are usually exported as 8-bit bitmaps.
Point Clouds
For data usage such as Tree or Rock scattering, or similar functions, you can also export masks as XYZ point clouds.
Normals and Splat
Gaea has dedicated nodes for Normal Map and Splat Map creation which are exported as 8-bit bitmaps. The Normal Map node can extract Detail Normals as well.
Gaea can export both Ambient Occlusion (AO node) and "rock occlusion" (Occlusion node). Rock Occlusion with specific masking or using the Shaper adjustment can often be used for Reflectance in PBR scenarios.
The Light node lets you use high-precision rendering to create a fully realized render that you can use for direct application on your object.
In this example below, the mountain uses a baked lightmap on an unlit shader in Blender to dramatically reduce rendering time.
See Build and Export for more specifics.
