Profiles and Batch Builds
This feature is to be introduced in Gaea 2.1 (ETA February 2025)
Build Profiles let you save all Build Settings in a named preset. If you find yourself creating multiple versions of your terrain, or creating different output types, you can switch between the different build settings swiftly with Profiles.
Using Profiles
To create a profile:
Open Build Settings.
Select the settings you want for a profile
Go to the Profiles tab and click Save Profile.
The "Load" button imports the selected build profile into the current build settings.
The "Save As..." button allows you to create a new build profile based on the current build settings.
The "Delete" button removes the currently selected build profile.
Running Batch Builds
You can execute multiple builds using saved profiles using the Batch Builds dialog. Go to Build menu > Batch Builds to open the dialog.
Queue the different profiles you want to build and execute the batch. You can also save the batch as a .bat file for later execution or modification.
The -profile <name> or -p <name> argument can be used to specify a profile during a Build Swarm execution. It is recommended that the <name> be wrapped in "" quotation marks to prevent incorrect parsing.
See also Creating Mutations
