Suspending Engine
The Suspend/Engine button, or the shortcut ` lets you toggle the Gaea engine. When the engine is suspended, all node processing is paused. You can still edit nodes and make changes, however nodes will not be updated and the viewport will be frozen.
Benefits of Suspending the Engine
Make several changes and avoid long reprocessing on nodes.
Edit more than one node, or restructuring a graph.
Edit heavy nodes that may take a longer time to process.
Edit nodes while working in 4K.
