Gaea can be deployed to a large number of workstations in multiple ways.
When installing to a network drive, it must be installed on a network share hosted as a drive and not a UNC path. Gaea may not work properly on UNC paths.
Unattended Installation
There are two ways to perform multiple installations / mass deployment - through a command-line sequence using or using a zip file for xcopy style deployment.
In either case, you should prepare an activation file or a copy of the offline license (see License Types for more information)
Create an Activation File
- Create a text file named
activate.lic(Notepad is fine). - Put only the license key in the file (no extra spaces, no additional lines).
- Copy
activate.licto the Gaea Data Folder (see Paths and Storage).- For mass deployment, place it in each user’s
AppData > Gaea Datafolder, or in the install folder as appropriate for your deployment setup.
On launch, Gaea will check if a license is already validated. If not, it will attempt to read and activate using activate.lic.
Command Line Installation
Run the install (typically Gaea-2.x.x.x.exe) either via UI or with command line
Command Line example:
Gaea-2.2.7.0.exe /VERYSILENT /SUPPRESSMSGBOXES /NORESTART /SP-
## additional flags
/ALLUSERS - install for all users (administrative install).
/CURRENTUSER - install for current user only (non-administrative install).
/LOG="filename" - to save a log to a specific file.
/DIR="X:\PATH" - override the installation folder.
Once the installation is finished, copy the license file to the Data Folder.
| Install Type | Flag | Typical Path | Data Folder Path |
| Non-Admin | /CURRENTUSER |
C:\Users\<user>\AppData\Local\Programs\Gaea 2.0 |
C:\Users\<user>\AppData\Local\Programs\Gaea 2.0\Data |
| Admin | /ALLUSERS |
C:\Program Files\QuadSpinner\Gaea 2.0 |
C:\Users\<user>\AppData\Roaming\QuadSpinner\Gaea\2.0\ |
If Gaea has not run yet, it may not have created the folder.
